2.21:1?
Concerning 2.21, 2.35 - I just used the one I'd seen mentioned, you get the idea though.
Interesting opinions here, it's certainly showing that some people would much rather have the maximum quality picture, while others would rather have the 16:9 either with letterboxing or cropping. I'd say it likely shows the main target audience :-)
Oh, and "why have these discussions started coming up" - I didn't know they had, I just wanted to see what others thought of it.
I myself will likely stick with 16:9 for the forseeable future, but it does seem a shame to bump up to 1080 horizontal lines then waste 1/6th or more (whatever the actual amount it) of them. Fact is for me that while I enjoy the full cinema effect, I'd rather make the most of the technology I paid for at the expense of fringe action.
Is this ever going to stop? Or will we soon end up with 360 degree thin strips around our rooms for the 'ultimate widescreen experience'?
I already think it's obscenely disproportionate.. Is it likely to stop here? Or will they be trying to convince us we need even wider aspect ratios once this one becomes a little tired?
(The keen eyed amoung you will have noticed I am not a home cinema enthusiast.. Just someone increasingly confused that no matter how widescreen a screen he see's whatever's being played inside them always seems even wider :S)
FFS not this again.
Then they should film the movies so they would fit on most peoples TV's.
Besides, in that example it's not that bad, most movies are even wider than that and literally use only half the screen height. I know I see more, but I don't care, I'd rather it use my entire TV. I don't mind movies like in your example... but when they take up only half my TV it's just stupid.
Directors do not give a crap about you watching the movie at home... they make the film to be shown in a cinema which can project whatever aspect ratio they choose.
Its not stupid that it only fills half of "your" tv because it wasnt designed to fill your tv, the people that made the film do not want others cutting up their work and frankly they make enough money and keep enough of the market happy doing things the way they want.
Clearly the market has become open minded enough to accept the shift from panned and scanned video for home viewing to original aspect ratios. If you don't like it i suggest you stick to pan and scan dvds on a 4:3 tv or shell out for the philips 21:9 tv as its the best your going to get.
This could go on forever... at the end of the day, everyone has their preference.
Personally, I do like it when a film fills the screen. When the 2.35:1, etc aspect ratios really bothered me was when watchign on my 37". So I upgraded to a 46" so a wide aspect ratio is now as large as watching my 37" zoomed, while not losing anything on the sides.
I don't think either way is better. My only suggestion to people who like the screen filled is to get a tele with good zoom functionality.
And Vila, Director's should give a crap how people will see it at home. A lot of the money they make is from home sales and rentals, and therefore should be a consideration.
Well, given that films have been filmed in a 2.35:1 or wider ratio for at least 50 years, it's hardly a new thing, and there isn't really anything to stop. It's the way it's always been.
If directors did care about how we viewed films at home all the films over 10 years old would be in 4:3 format. Thankfully they are not.
movies will be always be in the aspect they were designed for cinema release (enter aspect here director). If you wish no bars on your 16.9 tv (for a dvd/bluray release), then get a tv it does fit or live with bars...jesus.
So should they re-film or cut and ruin Great Classics like 'Ben Hur' or 'The 10 Commandments' just so they can 'Fit Your TV'
Here's a little something I found a while ago!!..
Aspect ratio Description
1.19:1 "Movietone" - early 35 mm sound film ratio used in the late 1920s and early 1930s, especially in Europe. The optical soundtrack was placed on the side of the 1.33 frame, thus reducing the width of the frame. The Academy Aperture frame (1.37) fixed this by making the frame lines thicker. The best examples of this ratio are Fritz Lang's first sound films: M and The Testament of Dr. Mabuse. This is also roughly identical to the ratio of the physical frame used for anamorphic photography today.
1.25:1 The British 405 line TV system used this aspect ratio from its beginning in the 1930s until 1950 when it changed to the more common 1.33 format.
1.33:1 35 mm original silent film ratio, commonly known in TV and video as 4:3. Also standard ratio for MPEG-2 video compression.
1.37:1 35 mm full-screen sound film image, nearly universal in movies between 1932 and 1953. Officially adopted as the Academy ratio in 1932 by AMPAS. Still occasionally used. Also standard 16 mm.
1.43:1 IMAX format.
1.5:1 The aspect ratio of 35 mm film used for still photography.
1.56:1 Widescreen aspect ratio 14:9. Often used in shooting commercials etc. as a compromise format between 4:3 (12:9) and 16:9, especially when the output will be used in both standard TV and widescreen. When converted to a 16:9 frame, there is slight pillarboxing, while conversion to 4:3 creates slight letterboxing.
1.66:1 35 mm European widescreen standard; native Super 16 mm frame ratio. (5:3, sometimes expressed more accurately as "1.67".)
1.75:1 Early 35 mm widescreen ratio, primarily used by MGM, and since abandoned.
1.78:1 Video widescreen standard (16:9), used in high-definition television, One of three ratios specified for MPEG-2 video compression.
1.85:1 35 mm US and UK widescreen standard for theatrical film. Uses approximately 3 perforations ("perfs") of image space per 4 perf frame; films can be shot in 3-perf to save cost of film stock.
2:1 Original SuperScope ratio, also used in Univisium.
2.2:1 70 mm standard. Originally developed for Todd-AO in the 1950s. 2.21:1 is specified for MPEG-2 but not used.
2.35:1 35 mm anamorphic prior to 1970, used by CinemaScope ("'Scope") and early Panavision. The anamorphic standard has subtly changed so that modern anamorphic productions are actually 2.39,[1] but often referred to as 2.35 anyway, due to old convention. (Note that anamorphic refers to the compression of the image on film to maximize a standard 4 perf academy area but presents the widest of aspect ratios.)
2.39:1 35 mm anamorphic from 1970 onwards. Sometimes rounded up to 2.40.[1] Often commercially branded as Panavision format or 'Scope.
2.55:1 Original aspect ratio of CinemaScope before optical sound was added to the film. This was also the aspect ratio of CinemaScope 55.
2.59:1 Cinerama at full height (three specially captured 35 mm images projected side-by-side into one composite widescreen image).
2.76:1 MGM Camera 65 (65 mm with 1.25x anamorphic squeeze). Used only on a handful of films between 1956 and 1964, such as Ben-Hur (1959).
4:1 Polyvision, three 35 mm 1.33 images projected side by side. Used only on Abel Gance's Napoléon (1927).
Anything filmed in an aspect ratio below the **-** will result in bars top and bottom.
How about some DIY boards that you place over the black bars on your TV? A full set of boards to cover all the aspect ratios, and hey, no black borders anymore... :rolleyes:
Having a 16:10 PC monitor, I get black borders on everything if I watch it on my PC or laptop.
You find that lower budget movies are shot in 16:9 whereas the high budget big movies choose a wider format and I personally think it kinda goes with the movies too. Comedies are also usually 16:9 too.
For a 'big' movie like lord of the rings, I really think a lower aspect ratio wouldn't have done it justice, movies like that just really suit a nice wide image. They just feel more immersive.
Given that most movies are 2.35 or 2.4, the bars on the Pirates scene sample look about right compared to my own widescreen TV. If the bars are half the screen, then I guess you have your PS3 set to 4:3 and are watching a massively squashed/distorted picture.
Or just a Projector and like at the Cinema get an adjustable screen and make it fit the aspect ratio!!... :)
Since when are screens for projectors anything like £2k?!
If you want 2 to 4 way masking you'll be lucky to get one for 2k.
I'm very close to ordering one of these:
http://www.carada.com/Masquerade-Masking-System.aspx
... but the credit card doesn't look happy.
Naaaa.. Just make one!.. couple of Motors and a Roller blind mechanism or summut!... Its only a suggestion cos of the 'Oh my God I've got Black Bars' moan!.. :p
I'm crap at diy!
The Dark Knight BluRay has the opening scene filmed in 16:9 (the bank raid) it then cuts to widescreen for the rest of the film, while the black bars don’t bother me too much (46” TV), I must admit the opening 16:9 part does look much more impressive then the rest of the film…(my humble opinion)
The 'impressive' nature of the 16:9 shots in the Dark Knight is also due to the fact that imax is a higher quality camera / film / lense etc
