Thanks reflux. The gtx260 I saw elsewhere is an XFX and has high memory/core clock speeds
I hope it has enough power for a 24".
For gods sake don't get an overclocked XFX card. Please please please do not make that mistake!!!!!!!!!!!!!!!!!!!!!!
How did you get the BFG OCX from here for £183 Inc![]()
Go for the Zotac 260 for £135incl in the This Week Only Deal. It should come with either Grid or FarCry2.
They were priced at £183 for a few mins yesterday afternoon then the price went up to £198.![]()
Is it worth paying an extra £50 or so for a BFG 260/216 or is the Zotac 260/192 better value at £135?![]()
No it isn't.If you are going with the 192 core version you should also consider the Radeon 4850 as it seems to be in the same league.
Correctomundo!the 192 core cards are only about 5% slower than the 216s.
 Wish i hadn't bought my £148 B-Grade card a week and a bit ago!
A friend of mine has just bought one of these.
So I can "rib him good" - what is bad about the XFX pre-overclocked cards?
so are the Zotac's at £135 65nm or 55nm? If the 65nm cards can oc better than the 55nm ones and the 192 pipes are only 5% slower than the 216 pipe versions then would the Zotac rival a 280 (near enough)???![]()
Good choice on the 260.Well I went for the £135 Zotac Zytok. Sorry couldnt resist!
At this price I wanted to get a second for sli but my mobo is a P45. Anyone know a good cheap SLI mobo that can overclock a dualie well? I really want to get a 2nd GTX260.
WHo said they overclock better? I would disagree with that statement.
