- 15 Nov 2008
What is the best graphics card for playing gta4 at max settings and at 1920x1200 resolution?
GTA4 is very CPU dependant, so as psychas said you need as powerful CPU as you can get + 1 gig graphics card (if you have less than 1 gig the game would not let you max settings).
I don't mind saying that my mates PC which is the same as mine (cpu, OC, RAM, resolution etc) is quite a bit faster with an 8800gtx than my 4850. Maybe the extra vram I don't know. My benchmark is 39/40 his is 48/49
I thought the 295 had 17** mb memory?
GTX 295
/close thread
Why, it runs at ~30fps at 720p (640p) with low details/draw distance on the consoles so 48fps at 1920*1200 is actually quite good.I can't believe nobody else has said that the problem with gta4 is that its a bad port ?
