How about jamex coilovers for the mondeo? (around £250 iirc) or some lowering caps for the front if they exist
[TW]Fox;13671444 said:That looks ridiculous. It's like you are giving a lift to two really fat birds.
Front will be lowered a bit more once i can find some suitable shorter shocks
Picked up the exhaust last night, it needs a flange putting on to join it to the cat pipe at the front of the car instead of bodging it on with an exhaust clamp, so its booked in next week to be fitted properly
I was quite shocked to see the bore size of the standard exhaust system, it must be 2.5" at least!
you do need a twin exit though![]()
