Just found this:
Abe's Odyssey and Exoduss FAQ
It says...
I also found that you can download a demo
Will see if it's playable
It says...
Steam Forums said:Q: What resolution does this run at?
640x480. There are NO options to change this in the game options
Q: The game looks horrible streched to my resolution!
DXWnd will allow you to play in a window, just add the two Abe's EXE's to it (and not Steam with -Applaunch!) and then you can use that to force the games into a slightly dodgy window. Problem with it though is that it doesn't automatically centre itself which can be a bit of a pain. Another alternative is to use the Nvidia workaround by using 'Flat Panel Scaling' feature and select 'Do not scale' which will center the game and 'black out' everything else so you don't see your desktop.
