If your PC doesn't have a digital out then the USB version would be the one to get. Once you have this you should be good to go.
gt
Sorry to be dense, but how can I tell whether I have a digital out? Is it a port on the sound card?
gt
It'll either be an optical output or a coax (looks like a phono connector). If you have realtek and the control panel, that will probably tell you![]()
Ugh, sorry, I'm really struggling here. I feel very stupid. Here's a picture of my card:
Is it one of those ports?
I checked the colour coding on wikipedia, but it only seems to mention analogue ports, though it describes the orange one as "speaker out".
Actually even though I know for sure that's the card I bought, the one that arrived has a pink microphone port but no orange port....
This made me larf! Its been slightly humiliating but I'm glad I posted that pic because the gasps of horror from the OCUK collective have motivated me to *really* do something about positioning.
.....positioning *can* make a huge difference to sound, and as rightly pointed out so does stability with bookshelf speakers.This DAC sounds like an ideal solution. I get the impression its THE budget DAC to go for, but I'm going to look into other products, check some reviews and price things up this evening.
But just to absolutely confirm, it can use a USB port and therefore on my next PC build I could actually not bother with a sound card at all?
As others have said you need to isolate the speakers, and looking at the picture it looks like they maybe too small for the room. The room is cluttered which will absorb sound. To get the best sound you need to prioritise the speakers and position above all else, something which your girlfriend will never understand.
. Regarding the clutter, I'm thinking of moving the bookshelf and apart from the monitor and other clutter on the desk there shouldn't be anything between the speakers... Seen as its my bedroom, clutter is unavoidable really >.>Cant you save up and buy an m-audio 2496? you can get them for about £50 and if it doesnt work out you can sell it on for a little less, and you can have 2 soundcards in your pc, one for music and one for games.
. Just kidding, the more suggestions the better, I'll weigh it up.you've got some stones posting that pic in here
.Awesome - looks like you're good to go then!An ASUS P5N32-SLI Premium. I just checked the manual and seemingly there is an orange port (just checked, there is) which is the Coax port, for "external audio". Thanks for clearing that one up.
Sounds interesting!!!the 7510 6/4 is a decent DAC for what is costs (especially 2nd hand) but the newer 7520 is in another league really and is only another £70 + you get the benefit of a nice USB connection and a much better headphone stage - if you could stretch the extra £££ i'd say it's easily worth it.
i've had both and for the money the 7520 is tremendous value, it's a lot more lively than the 7510 through the midrange + deeper bass. i had to tone down my equalizer settings when i plugged the 7520 in because the sound was just too aggressive. give it at least 100hrs to fully burn/bed in as it can sound quite harsh at first.
No doubt this will end up being my next purchase! All my good intentions to try and save always fail!!!![]()
gt
God... tell me about it!once you get on that carousel.....![]()
You might want to get a Beresford Dac. £110, is also a passive preamp and a headphone amp. Kills Dac's worth £1k+.
Also, you might want a subwoofer... i find they make the stage in home a lot brighter and overally meatier.
Something like a BK elec plate amp + this + make a box.
Secondly and most importantly, you are not used to how music should sound. A car stereo, cheap mini hifi and especially cheap spc speakers will sound bassy and tinny. You have jsut never heard midrange before and are having withdrawl symptoms from boomy bass and tinnyness![]()
gt
