***OcUK Vantage list MK2***
ahhh
my old core 216, how is it greebo ? u happy with it mate
chuffed to bits with it mate. Runs cool and quiet. Still trying to find the max of how far it will go.
Going under water later this week as well.
What was the max clocks you got on it?
http://service.futuremark.com/compare?3dmv=953735
new score added.
question: Do people clock the GPU high to run benches even if it creats artifects? If so is that safe? mine are at everyday clocks thats all
Ner, defeats the point. Although I did when I used to have my 8800GT, I was so determined to get 15,000 points on 3D mark 06. Having said that, it didn't artefact, just it wouldn't last much longer than 15 mins due to the heat. Funny thing was, I scored 15,000 precisely with it:D
August last year - http://service.futuremark.com/compare?3dm06=7764743
Fair enough.
But when I said it I cheated and looked at his screenshot.
http://img17.imageshack.us/img17/626/capturel.png
I'm also skeptical as to whether your bench was at 760mhz. Thats about 1000 above the normal score for that clock speed. Don't think any amount of tweaking could add that. I think you are mistaken.
Nope I saved it in the notes. However I have no screenshots now to prove it was only at 760.
But why would I make out it was at a lower clock than it was? It's on (or was on) the vantage database on here and there might be a screenshot on that.
However, that's what it scored and yes, I worked hard to get that score. Clean basic install of windows etc, pci-e slot overclocked etc.
3DMark Score P12880
CPU Score 36988
Graphics Score 10581
Submitted em too on that site.
http://service.futuremark.com/compare?3dmv=1304630
