Hi,
i have been a windows user ever since i can remember but since i have had the iphone i have been thinking about what a mac is like to use.
now the first think i can see different with macs is the price
but i understand that macs are not just your run of the mill pc so i can get around that.
now looking at the different types of Macs you can get i thought about giving a Mac Mini a go now i know some of you will say go for a mac book but i never get on with laptops as it always means at some time or another you have to get up and plug something in when you want it and although its nice to sit in another room and use a laptop i have always found it best sitting at a desktop.
another reason for looking at the Mini is that i am already running a dual display setup with vista so i could switch back to a single screen and use the other for the Mini and as i am a noob to Macs i just want something to get use to before i look at something like an imac and the mini although not that cheap is better than spending £930 on a 13" macbook when i can use a 20" desktop screen with the mini.
now if some of you can answer some questions for me please.
1, as well as using a 20" display i was also thinking to trying the Mini on my 37" 1080P TV so would the mini be OK for this ?
2, vista has a minimum amount of ram that people usually recommend which if i am correct is 2GB so what is the minimum for a Mac ?
3, if i was to buy the £499 Mini can i upgrade the ram to say 4GB i think i read somewhere that 4GB does not work to well in a mini true or false ?
4, if i do upgrade the ram after i got it would apple know, thinking about guarantee ?
5, how loud does the mini get and does the fans still run when put into sleep mode ?
5, if for some reason you need to reinstall the OS do you also have to reinstall all apps like you do in vista ?
6, i am using a 500GB WD my book if i used this on time machine to backup and i lost the hard drive on the mini will this restore it back to how it was before with all apps as well or just my files ?
7, vista does software updates every now and then do Macs do this as well and i also see that a new OS is due from apple so will this be an upgrade you have to pay for or will this be free if i was to but a mini within say the next week or two ?
8, Whats the sound like on a mini when put through some speakers, itunes user
now as i am a noob to macs any other advice would be grateful.
Tony
but i understand that macs are not just your run of the mill pc so i can get around that.now looking at the different types of Macs you can get i thought about giving a Mac Mini a go now i know some of you will say go for a mac book but i never get on with laptops as it always means at some time or another you have to get up and plug something in when you want it and although its nice to sit in another room and use a laptop i have always found it best sitting at a desktop.
Tony
