How to make a bike wheel quick release
Depending on the hub a replacement QR axle can usually be fitted. If its a loose ball bearing hub then a standard 110mm chromoly QR axle should do the trick.
If its a better, sealed bearing hub then they are usually designed specifically for that individual hub.
When I was doing it the other way (replacing QR with non-QR) I just went to Evans, bought some new skewers, took the old ones out and put the new ones in. It took about 3 minutes to do the change.
i think the OP has a solid axle and 15mm wheel nuts at the mo
