I know it's going to be a range from ambient to very hot depending on whats emptying heat into it and what is removing heat, but roughly what is the range?
If you empty 400W into the system and remove 400W from it, its presumably going to sit, on average, at ambient temperatures. The radiator efficiency increases with temperature, and it takes time for heat to diffuse. I take it this accounts for temperature being above ambient.
But what values are normal?
 Assuming two rads the obvious solution is to run the rads in parallel. Yay, lower pressure drop, this also halves the flow rate of the water through each rad. Common sense says this is good as the water spends more time in the cooling zone, but iirc the reality of the situation differs from what one imagines. At higher flow rates the water releases proportionately more heat to the rad then it does at lower flow rates, much the same way that water through a block removes more heat at higher velocity than it does at lower velocity.
