If you extract the drivers once downloaded, then do the Device Manager, Update Driver, and point it to the extracted 9.4's, the driver will install for Win7 apparently.
I tried this but it said best driver currently installed. Which folder did you use exactly?
odd these drives dont seem to support my x1900xt pcie or my x1950pro agp.
something not right here. back to 8.12 i guess.
Thanks for heads up.
The release notes are on the download page(https://a248.e.akamai.net/f/674/9206/0/www2.ati.com/gamesite/Catalyst_94_release_notes.pdf)
is the win 7 driver sorted yet?
Nope, just downloaded it and tried installing it. Catalyst Install Manager suggests that everything went OK, but checking the Rivatuner gadget shows I'm still using the WDDM driver.
Back on 9.3 until they fix it, I guess.
Whats with the new overdrive autotune? Just stays on that colour screen forever......
