- 18 Oct 2002
- England
Hi just need a bit of advice really Ive built a AM2 X2-6000 rigg for a m8 and nothing but nightmares for past 2 weeks since ive built it.
Using an Akasa 876 Cooler and even 3 other £15-25 heatsink jobbies I cant get this thing too run stable, it idles at around 40-45c and running toast or few apps looped like Norton Scan/Windows media player can hit 55-65c however running Orthos puts it too a staggering 80-95c !
It doesnt last long running at 95c it just alarms and switches off.
I belive its a Brisban Core and Doing some google search suggest this chip had a defective Temp sensor?
Someone suggest its using much higher volts is it ok for me too lower the Volts and how much should I try ?
Any other ideas btw the guy who said his X2-6000 overheats had a Sunbeam Core contact cooler ! and I was just considering buying that!
