I've noticed no difference on the rig in my sig.
I'm leaving it alone then
COD4 still not fixed?
Can regular home users download a Windows 7 trial? If so, where from?
Could somebody please tell me if it's possible to upgrade from Vista x32 to windows 7 x64 without losing any files? Or would i have to install the 32bit version of windows 7?
loadsa, ms have said that we won't be able to upgrade from beta to final/rc..
Thats a bit of a ****** then![]()
as Skeeter on the last page said, a fresh start for the RC is a good thing, no hangovers from multiple tweaking /changes from previous builds
so all RC users are on a fresh install, instead of ms chasing their tail with reported non-issues![]()
Stuck x64 7077 yesterday over 7068 and find it much more stable. I feel I can use this almost as my primary OS. To be honest Windows 7 offers nothing to me over what Vista already has. In some cases I find Vista better, such as creating shortcuts on task bar. Try to create a short cut for Recycle bin or Computer or Games explorer. It just "pins" it to the explorer menu (which is rubbish, I want to see my drives, not those libraries.
This should be a service pack or theme for Vista.
this is the only problem i have with Windows 7...i want to put shortcuts on the taskbar...am i missing something?
Drag the item to the taskbar? Or right-click, pin to taskbar?
doesnt always work as it should.. ie dragging my computer there or pinning it there.. just loads "libraries" when u click on it![]()
