just a quick one
youd benefit if you went to 4 gig, the difference in the 2 speeds isnt really noticable but the faster stuff does allow you to OC you CPU easier at higher FSB's
And depends really on how you use the system. It will make more of a difference in gaming and multimedia processing. But first you should get more RAM. 2GB is not optimal.
hi, would i benefit upgrading from pc6400 to pc8500. i currently have 2 x 1gb of corsair XMS2 pc6400 800mhz ?
I would go for this...
Corsair Dominator 4GB (2x2GB) DDR2 XMS2 PC2-8500C5 TwinX Supplied with Airflow Fan (TWIN2X4096-8500C5DF)
1066MHz RAM Speed, CAS 5-5-5-15 Timings, 2.1-2.2v VDIMM, Lifetime Warranty with Corsair.
£68.99 on Overclockers is a great price.
I would go for 4gb of Kingston:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-039-KS
At £43 its a seal!
Edit:
Or there is the OCZ with worse timings but its only £34:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-149-OC&groupid=701&catid=8&subcat=817
Kingston... some motherboards are a little fussy when it comes to Kingston memory, Gigabyte do not like mix-n-match memory when it comes to Kingston memory. I would recommend either Corsair or OCZ. From past experience with memory.
thanks for the replies. yes i was looking at getting 4b. i would like to ask about the timings, i have no idea ? what is a good timing and how is one better than the other. thanks
Most PC8500 is rated at CAS5 or higher aka slower. Also, if you are not OCing your CPU then you will see a minimal gain by ONLY increasing the memory frequency. So, unless you are going well past a 400FSB then the PC6400 is fast enough.
However, if the price for 4GB of PC8500 is very similar to 4GB of PC6400, then you can't go wrong with the 8500. It will be a bit faster at stock or OCed.
