but yeah longer primes would be appreciated, might get one of the D0s myself.
im just eager - its been going since 20:34, i will post an updated screen once a few hours have passed
]What speed are you trying to run the ram at?
So those temps are on water?
Was wondering if you have considered a Push - Pull setup on your 120.1?
rjkoneill, I'm not sure if I'm reading it right but it looks like maybe you taken the top prize for shortest ever Prime screenshot published on OcUK, title currently held by easyrider for a 19 seconds prime screenie!![]()
well it runs at 1600 at 4.2 as 1800/1866 isnt available
it seems to be at 1600 on all my profiles i made so far
3.6ghz
3.8ghz
4ghz
4.2ghz
but like i said - ive only had the board a day - will probably figure out hwat part of the bios im noobing up! lol![]()
but if you want the full ram speed, you could try a higher bclk and lower multi. I assume you're using the latest 304 bios although not much was added over the previous ones..
grrrrrrrrr but at stock it's fine. Maybe missing something in the bios. There's a lot to learn with these new i7's
i'm still miffed . . .grrrrrrrrr
