Has anyone overclocked the EVGA gtx 260 SSC 55nm yet? I was wondering what I can look to acheive.
<snip>
GPU-Z doesn't detect the 2D frequencies but Rivatuner does and the card is running about 6-10c cooler at idle
You sir, are a lovely man
P13600
Only done a few runs but seams crash with display driver error once I go over 705 on core.
xfx 260@705/1478/2320
Be intresting to see what people are getting with there 4870 and 4890's
For people with Gainward GTX260 216 Golden Sample cards with part numbers EAN 4260xxxxx0025 only
This fixed bios solves issues with 2D clocks and voltages running at 3D settings. It should save you electricity and extend the life of your card.
You need these files.
0025 BIOS
NVFlash
Instructions.
1). Read the sticker on your card to confirm part number. It must begin 4260 and end 0025.
2). Make a DOS bootable floppy or USB disc (use Google if you do not know how).
3). Copy above bios and unziped NVFlash onto disk.
4). Change PC bios (if necessary) to boot from floppy.
5). Boot from Floppy
6). Backup original bios with command "NVFLASH -B BACKUP.ROM"
7). Flash new bios with command "NVFLASH -5 -6 0025260.ROM"
8). Hit "y" key when prompted and hold your breath.
9). Restart your PC and check 2D clocks work correctly.
If you brick your card it is your fault for following instructions an unknown person posted on the web. However, this is the official FIXED Gainward bios which I sourced directly from the Gainward Tech Support chaps in Germany. It worked for me.
This will not work on any other card because Gainward (it's actually made by Palit for Gainward) use non-reference parts.
This info is not available anywhere else (yet), so all credit goes to me.
Greebo
Snip.
First go. Obviously CPU limited at this time, but still.
675/1458 Shader/1161 Mem
Vantage: 12,558
CPU: 10,582 GPU 29,169
Temps no problem
Card in sig.
2nd attempt:
Artifacting @ 725/1216/1563
Will try 700 core later.
What temp should I be looking for in games with my evga gtx 260 ssc core 216?
I seem to max at at 70c at 690mhz core clock. Is this okay? Could I have the core clock higher?
core is prolly fine, unlink the core/shader clock and back the shader clock down below 1500 (think 1458 is the next increment below 1500) and it should be fine upto 729 core.
Depends on what your fan is running at? Have you left it at 40%?
70C is fine btw and from memory the fan profile won't have even upped it's speed by then (or maybe just up one step)
My card maxes out at 70C but for the silly maximum clock speeds it really doesn't like anything more than 64C before it artifacts etc so I need to ramp up the fan speeds to keep it cool enough and artifact free.
at 729/1542 I can just leave it on the stock profile.
70c at 47% fan. What temp is good to run at? like would 75c be acceptable?
