Overclocking an i7 920 D0 - 4.7GHz
rjk
rjk
OcUK Staff
8 Aug 2007
today i have been busy giving my chip a thrashing
after the untimley demise of my p6t deluxe [RIP] and with it my old 920 and memory
i decided to use a new setup
Biostar TPower X58 motherboard
i7 920 D0 stepping
OCZ 6GB 1866MHz Reaper HPC
along with my existing GTX 280 SLI
the D0 chip is already a massive improvement over my old chip
although the memory and board were holding me back before
my memory would only go to 1600 and nothing more
my board was bclk limited at 200
the chip is being cooled by a thermochill triple radiator
all of the overclocks have hyperthreading enabled- this is because hyperthreading is made of actual win ;)
STARTING OUT
i started out at 3.8GHz using stupidly low volts - easy enough :p
4GHz was a breeze - using 1.25v
PRIME STABLE
4.2GHz @ 1.298v passed prime for 8 hours
4.3GHz @ 1.328v also passed prime for 8 hours and will be used as my 24/7 profile using speedstep
BENCHMARK STABLE
seeing how far the chip could go in prime left me at 4.3ghz
i tried 4.4ghz @ 1.4v but got errors after a few minutes
being intreagued at how far i could go with this before the BCLK limited me
i pushed for 4.5GHz @1.4v
whilst not prime stable - it did a damn good job in 3Dmark Vantage:cool:
PUSHING FURTHER
i couldnt get stability in vantage after 4.58GHz
but i was eager to see what the maximum BCLK i could get out of the board was. turns out the BIOSTAR X58 goes all the way to 222 BCLK! :eek:
something i have yet to see even a Rampage Extreme II obtain!!!
so i had to try the next test using super pi as Vantage crashed on the third test no matter what i did.
4.66GHz @ 1.456v
super pi wouldnt do a 32m run - but the rest of the entries are impressive enough
i managed to get into windows at 4.73GHz but it crashed when any application loaded
here are my HWBOT submissions with these overclocks
SuperPI @ 4.66GHz
CPUZ @ 4.66GHz
EDIT***
after trying to get it past 4.66 i have given up
it wont do it - looks like 222 is my bclk wall
shame :(
cant wait to see a 950/975 in action if this is the standard of the :)
Pretty sweet.
I have the same RAM and I managed to get the timings to 8/8/9/24/1T @1600mhz without really trying. I'm sure you could easily beat that.
If you're push ur cpu that hard might as well whip everything else in ur build until it falls dead on its back :p
Awesome! I am selling my regular 920 now and buying a D0 stepping one! I don't care about the fact I'll loose out on £60 :)
Pretty sweet.
i did that last time and my rig died! :eek:
however - this ocz 1866 reaper beats my old 1600mhz dominator hands down
i pushed it to 2000mhz at stock timings and it sat there all day laughing at memtest!!!
not bad for £100 memory considering i paid £200 for the dominator 1600 on release!
i had to slacken the memory off on this occasion in order to eliminate it from the overclock - that way i could concentrate my efforts on my chip :p
its worth it - without a shadow of a doubt
i may have got lucky - but in the right board - these chips are monsters
Definately worth seeking one of these out over any other stepping then, i7 gets more and more tempting as time goes by.
i would agree
personally i wasnt sold - but the low voltage requirements compared to my old C0 stepping chip is just great
im pretty sure 4.66GHz is the highest im going with HT on
ive overclocked a lot of the 965's at work and the best one i saw did 4.3GHz
im liking this Biostar more and more
its on par with gigabyte's fantastic UD5
and beats the p6t deluxe hands down in my opinion
also - futuremark ORB system seems to pick my chip up as a 975 when its overclocked past 4.5GHz :confused:
hope they fix this
@ rjkoneill
What CPU PLL voltage are you using m8? I have to use 1.8952 to get 4.2Ghz stable.
In addition, I have to use 1.35V for QPI/DRAM. Everything else is set to AUTO. Other than the 1.312Vcore of course.
My Asus R2E also seems to be BCLK limited to around 200-205Mhz for some reason :-(
cpu pll is two notches above auto
sorry i dont know the exact amount [on my phone at the moment/ not at the pc]
my old p6t deluxe used to need 1.325 QPI/DRAM to get stable over 4ghz
i noticed that bclk limits rampages
its stupid how a £300 extreme overclocking board gets bclk limited at 205
whereas the original 775 rampage had the highest fsb out of all the x48's
my biostar posts at 4.8GHz [230 BCLK] but BSOD's on the windows loading bar
Nice one thanks. I'm thinking about the EVGA Classified for my next board.
I like the R2E, however, it's not as good as they (Asus) say it is.
I have the REII and with my C0 i could easily run at 215 BCLK....ran at 19 x 215.
Not tried with my current D0 yet.
rjkoneill....is that prime small fft's or blend stable??
I might tempt to buy Biostar TPower X58 motherboard and fit my new i7 920 D0 cpu and domino A.L.C coolit and I reckon it might do well 5Ghz ! Do u think it can get to 5Ghz ?
Doubt it as most boards would be limited to around 222mhz bclk if you're lucky (although I've seen 230 on a DFI) with a max multi of 21x. That would only give you about 4.6ghz. I would have thought that what Rjkoneill got is pretty much the maximum you can get on an i7 920.
