- 20 Apr 2008
- West Midlands
If I put the cpu voltage to that amount, then would I need to change anything else? Or would I only need to change stuff if I put the cpu voltage higher?
I am using 1600mhz patriot viper @ 1.65v btw. So would I be okay to put volt at 1.66? aas it doesn't let you do it at 1.65, although the mobo said that anything above 1.65 is dangerous?
In my bios my cpu voltage is @ 1.296v
when running prime it jumps between 1.288v and 1.302v but mainly stays @ 1.296v
my ram is set @ 1.64v as like you say not allowing me to set it @ 1.65v.
as for other settings i will have to get back to you as i know i've turned things off and raised others. I'll take a look tonight and let you know
