- 7 Mar 2005
- LU7
Just tried this out and it isn't at all bad.http://lifehacker.com/5221047/update-notifier-finds-newer-versions-of-windows-apps
An alternative to FileHippo's update checker.![]()
When you run it, it gives you the option to install it OR run it as a portable program.When it shows updates it takes you to http://cleansofts.org/utorrent.html say for a new build of uTorrent, I was hoping it would direct you to the official site for a program.
It also has a tab where it suggests some alternatives programs to the programs its detected on your PC.
