I thought it was Preserve if they are talking about Jam?
Never ask an American for a kettle, they look at you like you just walked out of the Victorian era.
Well a kettle to them is the quaint variety you use on a stove. They didn't quite understand what I was after so I ended up boiling the water in a pan to make some teaWhat do you ask for then?
Rounders = Baseball
I guess it's really about how you interpret these things, it'll still bug me either way, though. Really it's just the fact that the phrase 'I couldn't care less' is often used in a context where the speaker is trying to dismiss or undermine whoever they're talking to's point that gets to me about the misuse of that phrase. The fact that somebody has just said they 'couldn't care less' (typically without reason) about a subject that has been brought up is usually irritating enough for those that do care, then the misuse of the phrase just compounds the issue.
Question though, what on earth do they boil the water for coffee in?
What do you call thisWe dont use crappy instant coffee so most people use a coffee maker
using fresh coffee beans which are very cheap to buy.
This one has given me the giggles in a business meeting beforebackside=fanny
Pronunciation of Aluminium is different because they spell it differently too (Aluminum).
aluminum1812, coined by Sir Humphry Davy (1778-1829), from L. alumen "alum" (see alum). Davy originally called it alumium (1808), then amended this to aluminum, which remains the U.S. word, but British editors in 1812 further amended it to aluminium, the modern preferred British form, to better harmonize with other element names (sodium, potassium, etc.).
Aluminum is the correct name.
It's the original name. Aluminum is correct in America, while Aluminium is correct in Britain.
