- 18 Oct 2002
- Way up High.
Repeat a landing or repeat faking it ??
Cost.If the Americans managed to do this in 1965 then surely China could do this in 2008? Why would the need to fake something that Americans managed to do 40 years earlier? Can't be that hard...can it?
You'd never see "wobble". That at the very least requires friction, which there isn't much of in near vacuum. Most craft 'steer' using jets of gas. These don't impart much force because the last thing you want is a craft spinning off uncontrollably (it's much easier to start moving than it is to stop).The only thing that i find strange about the video is the position of the earth. I've never tried flying a space craft but i'd imagine that its quite difficult to get perfectly stable at the speed its going and surely even a few degrees of rotation would be noticeable because of the distance away from earth?
Even "fixed orbit" satellites are not perfectly stationary and "wobble" a bit iirc (may be wrong about this though)
Which China couldn't give a damn about. Look how much they spent on the Olympics. Their goal is simply to do whatever it takes to become a space-faring nation. The same was true of the US in the 60s, for much the same reason - politics.Cost.
Yeah, although it does seem pretty difficult for America to repeat that kind of feet lately.
At exactly the right speed? And why doesn't it move in the shot?
That's Geostationary satellites. They operate at a far higher altitude than any current manned spacecraft (which orbit the earth approximately once every 90 minutes).
So there's no chance that the craft was in a geostationary orbit?
If so that's buggered that explanation then.
The only things I'm still iffy about in the video are that all debris/bubbles shoot straight up far faster then they should given that the hatch was open so long there's no chance that there was that much gas still coming out, it also doesn't explain why the debris later on coming from different areas shoot upwards too. Granted if the object was slowed, ie pushed backwards from the direction of orbit it would slowly start to "sink" towards the earth due to lack of speed. To say that any object would react like those did though is ludicrous.
huh? there have been loads of televised/filmed space walks from America/Russia in the last few years.
If you're saying thier faked you're going to have to explain how they fix/upgrade Hubble.
shouldnt there be stars in the background?
It's a good job that satellites go at exactly the same speed as the Earth or else I wouldn't be able to pick up SKY, Astra, Hotbird or Thor.
It's called a geostationary orbit.
Anyway, 1000s upon 1000s of NASA professionals must have followed, tracked, watched and analysed this walk but some 15 year old cries FAKE.
It was made in china, it is to be expected![]()
Yes but all objects will be attracted equally, so the clips would not float towards the earth independently of the main ship. (Although this is obviously not enough proof on its own - could be down to the flexibility of the ropes or something)
Rather old source there - given that Mir and Columbia both no longer exist. I think the ISS, and probably the Chinese, operate at a lower altitude, but you're absolutely right - nothing like Geostationary.
