- 10 Apr 2006
- North West
102.81
Core2Duo 2.33ghz
3GB
ATI X1600
Core2Duo 2.33ghz
3GB
ATI X1600
Results 178.35
System Info
Xbench Version 1.3
System Version 10.5.6 (9G55)
Physical RAM 4096 MB
Model MacBookPro3,1
Drive Type OCZ-VERTEX 1199
Disk Test 178.35
Sequential 131.92
Uncached Write 202.55 124.36 MB/sec [4K blocks]
Uncached Write 176.07 99.62 MB/sec [256K blocks]
Uncached Read 66.59 19.49 MB/sec [4K blocks]
Uncached Read 213.40 107.26 MB/sec [256K blocks]
Random 275.19
Uncached Write 116.55 12.34 MB/sec [4K blocks]
Uncached Write 327.73 104.92 MB/sec [256K blocks]
Uncached Read 2173.79 15.40 MB/sec [4K blocks]
Uncached Read 409.19 75.93 MB/sec [256K blocks]
Results 181.13
System Info
Xbench Version 1.3
Model MacBookPro3,1
CPU Test 149.40
GCD Loop 280.41 14.78 Mops/sec
Floating Point Basic 135.78 3.23 Gflop/sec
vecLib FFT 109.10 3.60 Gflop/sec
Floating Point Library 149.79 26.08 Mops/sec
Thread Test 217.24
Computation 213.84 4.33 Mops/sec, 4 threads
Lock Contention 220.74 9.50 Mlocks/sec, 4 threads
Memory Test 162.06
System 168.95
Allocate 271.17 995.82 Kalloc/sec
Fill 137.67 6693.76 MB/sec
Copy 146.94 3035.05 MB/sec
Stream 155.70
Copy 146.52 3026.33 MB/sec
Scale 145.15 2998.81 MB/sec
Add 167.35 3564.82 MB/sec
Triad 166.67 3565.57 MB/sec
Quartz Graphics Test 171.98
Line 162.67 10.83 Klines/sec [50% alpha]
Rectangle 203.56 60.77 Krects/sec [50% alpha]
Circle 162.33 13.23 Kcircles/sec [50% alpha]
Bezier 169.24 4.27 Kbeziers/sec [50% alpha]
Text 168.23 10.52 Kchars/sec
OpenGL Graphics Test 168.19
Spinning Squares 168.19 213.35 frames/sec
User Interface Test 300.18
Elements 300.18 1.38 Krefresh/sec
Disk Test 164.28
Sequential 119.02
Uncached Write 199.98 122.79 MB/sec [4K blocks]
Uncached Write 128.31 72.60 MB/sec [256K blocks]
Uncached Read 61.27 17.93 MB/sec [4K blocks]
Uncached Read 222.57 111.86 MB/sec [256K blocks]
Random 265.09
Uncached Write 116.30 12.31 MB/sec [4K blocks]
Uncached Write 241.57 77.34 MB/sec [256K blocks]
Uncached Read 1763.10 12.49 MB/sec [4K blocks]
Uncached Read 560.54 104.01 MB/sec [256K blocks]
Results 58.33
System Info
Xbench Version 1.3
System Version 10.4.11 (8S165)
Physical RAM 1536 MB
Model PowerMac8,1
Processor PowerPC G5 @ 1.80 GHz
L1 Cache 64K (instruction), 32K (data)
L2 Cache 512K @ 1.80 GHz
Bus Frequency 600 MHz
Video Card GeForce FX 5200
Drive Type Hitachi HDP725050GLA380
CPU Test 96.08
GCD Loop 72.12 3.80 Mops/sec
Floating Point Basic 98.86 2.35 Gflop/sec
AltiVec Basic 208.16 8.30 Gflop/sec
vecLib FFT 92.09 3.04 Gflop/sec
Floating Point Library 80.69 14.05 Mops/sec
Thread Test 49.46
Computation 41.07 832.10 Kops/sec, 4 threads
Lock Contention 62.16 2.67 Mlocks/sec, 4 threads
Memory Test 53.46
System 51.97
Allocate 103.06 378.49 Kalloc/sec
Fill 52.42 2548.66 MB/sec
Copy 34.55 713.57 MB/sec
Stream 55.03
Copy 50.04 1033.62 MB/sec [G5]
Scale 53.79 1111.30 MB/sec [G5]
Add 57.90 1233.29 MB/sec [G5]
Triad 59.38 1270.38 MB/sec [G5]
Quartz Graphics Test 71.76
Line 73.12 4.87 Klines/sec [50% alpha]
Rectangle 75.66 22.59 Krects/sec [50% alpha]
Circle 80.87 6.59 Kcircles/sec [50% alpha]
Bezier 77.86 1.96 Kbeziers/sec [50% alpha]
Text 56.90 3.56 Kchars/sec
OpenGL Graphics Test 78.73
Spinning Squares 78.73 99.87 frames/sec
User Interface Test 42.12
Elements 42.12 193.32 refresh/sec
Disk Test 49.25
Sequential 64.21
Uncached Write 48.13 29.55 MB/sec [4K blocks]
Uncached Write 39.25 22.21 MB/sec [256K blocks]
Uncached Read 98.23 28.75 MB/sec [4K blocks]
Uncached Read 170.47 85.68 MB/sec [256K blocks]
Random 39.94
Uncached Write 15.00 1.59 MB/sec [4K blocks]
Uncached Write 72.17 23.11 MB/sec [256K blocks]
Uncached Read 80.72 0.57 MB/sec [4K blocks]
Uncached Read 138.12 25.63 MB/sec [256K blocks]
Results 210.33
System Info
Xbench Version 1.3
System Version 10.5.6 (9G3610)
Model iMac9,1
Drive Type WDC WD1001FALS-40K1B0
CPU Test 206.38
GCD Loop 358.10 18.88 Mops/sec
Floating Point Basic 173.14 4.11 Gflop/sec
vecLib FFT 144.27 4.76 Gflop/sec
Floating Point Library 257.62 44.86 Mops/sec
Thread Test 386.64
Computation 497.06 10.07 Mops/sec, 4 threads
Lock Contention 316.36 13.61 Mlocks/sec, 4 threads
Memory Test 208.76
System 251.59
Allocate 415.81 1.53 Malloc/sec
Fill 197.84 9619.28 MB/sec
Copy 223.98 4626.20 MB/sec
Stream 178.40
Copy 168.23 3474.80 MB/sec
Scale 170.77 3528.15 MB/sec
Add 188.40 4013.37 MB/sec
Triad 188.17 4025.49 MB/sec
Quartz Graphics Test 237.46
Line 236.83 15.77 Klines/sec [50% alpha]
Rectangle 265.67 79.32 Krects/sec [50% alpha]
Circle 225.87 18.41 Kcircles/sec [50% alpha]
Bezier 231.37 5.84 Kbeziers/sec [50% alpha]
Text 231.47 14.48 Kchars/sec
OpenGL Graphics Test 241.91
Spinning Squares 241.91 306.88 frames/sec
User Interface Test 444.92
Elements 444.92 2.04 Krefresh/sec
Disk Test 95.54
Sequential 144.80
Uncached Write 177.40 108.92 MB/sec [4K blocks]
Uncached Write 173.04 97.90 MB/sec [256K blocks]
Uncached Read 86.40 25.28 MB/sec [4K blocks]
Uncached Read 215.78 108.45 MB/sec [256K blocks]
Random 71.29
Uncached Write 25.73 2.72 MB/sec [4K blocks]
Uncached Write 305.57 97.82 MB/sec [256K blocks]
Uncached Read 114.80 0.81 MB/sec [4K blocks]
Uncached Read 190.14 35.28 MB/sec [256K blocks]
Results 159.59
System Info
Xbench Version 1.3
System Version 10.6 (10A432)
Model MacBookPro3,1
Drive Type OCZ-VERTEX 1275
CPU Test 167.36
GCD Loop 280.98 14.81 Mops/sec
Floating Point Basic 135.22 3.21 Gflop/sec
vecLib FFT 108.76 3.59 Gflop/sec
Floating Point Library 266.49 46.40 Mops/sec
Thread Test 216.73
Computation 215.66 4.37 Mops/sec, 4 threads
Lock Contention 217.81 9.37 Mlocks/sec, 4 threads
Memory Test 164.36
System 178.62
Allocate 382.79 1.41 Malloc/sec
Fill 137.25 6673.60 MB/sec
Copy 144.98 2994.51 MB/sec
Stream 152.22
Copy 144.12 2976.79 MB/sec
Scale 143.07 2955.88 MB/sec
Add 162.17 3454.47 MB/sec
Triad 161.70 3459.22 MB/sec
Quartz Graphics Test 182.06
Line 158.93 10.58 Klines/sec [50% alpha]
Rectangle 206.51 61.65 Krects/sec [50% alpha]
Circle 175.23 14.28 Kcircles/sec [50% alpha]
Bezier 182.24 4.60 Kbeziers/sec [50% alpha]
Text 194.75 12.18 Kchars/sec
OpenGL Graphics Test 83.12
Spinning Squares 83.12 105.44 frames/sec
User Interface Test 258.45
Elements 258.45 1.19 Krefresh/sec
Disk Test 172.50
Sequential 139.29
Uncached Write 193.89 119.05 MB/sec [4K blocks]
Uncached Write 198.06 112.06 MB/sec [256K blocks]
Uncached Read 69.73 20.41 MB/sec [4K blocks]
Uncached Read 239.81 120.52 MB/sec [256K blocks]
Random 226.48
Uncached Write 80.32 8.50 MB/sec [4K blocks]
Uncached Write 337.29 107.98 MB/sec [256K blocks]
Uncached Read 1799.96 12.76 MB/sec [4K blocks]
Uncached Read 591.24 109.71 MB/sec [256K blocks]
Results 177.83
System Info
Xbench Version 1.3
Model MacBookPro5,1
Drive Type INTEL SSDSA2M160G2GC
CPU Test 169.08
GCD Loop 279.49 14.73 Mops/sec
Floating Point Basic 135.39 3.22 Gflop/sec
vecLib FFT 111.56 3.68 Gflop/sec
Floating Point Library 268.12 46.69 Mops/sec
Thread Test 323.42
Computation 401.84 8.14 Mops/sec, 4 threads
Lock Contention 270.61 11.64 Mlocks/sec, 4 threads
Memory Test 189.97
System 231.39
Allocate 391.38 1.44 Malloc/sec
Fill 176.42 8577.96 MB/sec
Copy 210.88 4355.71 MB/sec
Stream 161.12
Copy 155.26 3206.73 MB/sec
Scale 151.01 3119.82 MB/sec
Add 170.37 3629.21 MB/sec
Triad 169.70 3630.32 MB/sec
Quartz Graphics Test 190.71
Line 162.94 10.85 Klines/sec [50% alpha]
Rectangle 218.87 65.35 Krects/sec [50% alpha]
Circle 188.20 15.34 Kcircles/sec [50% alpha]
Bezier 192.08 4.84 Kbeziers/sec [50% alpha]
Text 200.31 12.53 Kchars/sec
OpenGL Graphics Test 82.26
Spinning Squares 82.26 104.36 frames/sec
User Interface Test 272.22
Elements 272.22 1.25 Krefresh/sec
Disk Test 248.77
Sequential 161.84
Uncached Write 139.67 85.76 MB/sec [4K blocks]
Uncached Write 128.06 72.46 MB/sec [256K blocks]
Uncached Read 136.59 39.97 MB/sec [4K blocks]
Uncached Read 412.15 207.14 MB/sec [256K blocks]
Random 537.44
Uncached Write 665.17 70.42 MB/sec [4K blocks]
Uncached Write 236.88 75.83 MB/sec [256K blocks]
Uncached Read 1447.87 10.26 MB/sec [4K blocks]
Uncached Read 973.60 180.66 MB/sec [256K blocks]
