Real Lifesis (Crysis mod)
because there isnt a system on planet what run crysis on full whack, so u must have dipped down to no more then 3fps after putting it on full graphics
For your Information my FPS is between the low 30's and high 40's.
Please look at my sig for rig details
didn't think it was at all possible to get crysis at max detail at 1920x1200 with 16xAA with even 2x295's
However note the FPS in the screenshots with the depth of field at 2 and then 1. The final FPS is without the mod
We'd need to change the config ourselves it seems. In my opinion the graphics settings for in the distance beyond the depth of field are too unnecessarily high.
Tried this earlier on ToD2
Does look nice but as has been said i think the depth of field might be a slight intense as standard.
Ive just tried it with DX10 full detail and 16xAA and had a steady 23+ fps :eek:
thats with just 1 260GTX
but thats only with 1280x720, does anyone know why in DX10 mode it wont let me go any higher then this res?
I didn't realise that the key to rendering truly realistic graphics was just to take any game and set the depth of field to bat**** insane.
lies sexy women in RL look better than women in a game by far :p
Theres no sexy women in crysis. I think more people go wow over crysis than when they see a jungle. We are used to seeing jungles and stuff now but are more impressed when we see a pc rendering one. The last statement was a joke anyway.
It looks quite good but compairing it to ultra settings it still looks no where near as good. I do like the depth of field but at 2 its way too high. 1 is good but does not increase FPS. Instead of having everything there and blurring it they should have tried making it reduce draw distance, foliage etc when 2 is set and increase when 1 is set.
maybe this couldnt be done as a level reload must be needed to reduce object detail, draw distance and other stuff like that
Are you using XP? I know in Vista I can set the details to Very High on DX10. I can get a steady 30-40+ FPS using full res of 1920x1200 2xAA and with VERY HIGH settings across the board. :D
I have a 4870 X2. I had 32xCFAA, 16xAF along with 1920x1200 and VERY HIGH settings. I was getting 3FPS...I will try with 16xCFAA and 16AF. In game itself tho you can only go as high as 8xAA so using the CFAA can certainly help. :D
