- 13 Jan 2004
- South East
What about the time it takes to login? Or should I turn that off for this test?
might as well use autologin guys
control userpasswords2
you can always set the pc to automatically lock when it does login (using psshutdown )
if anyone gets local access to your pc, they'll be able to get in anyway![]()
OP: you're = you are. you mean: your. please fixcheerz
