Simple PHP If Statements - Help
31 Oct 2005
Leeds
Hello there again, I've left you alone for a while and only have a quick question this time
I currently have a piece of code that finds the number of a user, and kicks out their picture from file, only problem is, if there isn't a picture, it displays an error message.
Put simply, I'm after something like, "if $file <0 then display somefile.jpg"
Should be a 5 second job for some on you, would be much apperciated
Here's the PHP
PHP:
<?php
foreach (glob("$d_no.*") as $file) {
echo '<td>' . "<a href='$file' target=_blank><img  src='$file'  alt='$file'  width='180' height='300'></a>" . '</td>';
echo '</table>';
But if no files match the pattern then the for loop wont even execute once will it? You might need to store it in an array first, something like this:
PHP:
<?php
$files = glob("$d_no.*");
if(sizeof($files) > 0) {
 // There are some files
 foreach ($files as $file) {
} else {
// Do something else
echo '</table>';
I haven't used glob before so don't know if this will work!
Cheers for the PHP attempt, I tried
PHP:
<?php
} else {
echo '<td>' . "<a href='/test.jpg' target=_blank><img  src='$file'  alt='$file'  width='180' height='300'></a>" . '</td>';
echo'</table>';
echo '</table>';
Which works fine on users with pics, but alas the same error without
Warning: Invalid argument supplied for foreach()
