Squat Stands/Racks for 5ft Bar?
10 Dec 2004
North West
I'm having trouble finding a relatively cheap set of squat stands for a 5ft bar. Most I have found are either too big or too expensive so if anyone knows of a set for a reasonable price i'd appreciate it:)
Since they're independently positionable I can't see a reason why they wouldn't be suitable for a 5' bar. Might it be worth considering getting a longer bar if you can't find suitable racks?
Those will work with a 5ft bar fine seeing as they're seperate - but only support up to 115kg :( would this be enough for you?
Yeah, I expect they will be enough for me for at least a year yet and probably more. I've only been using the gym in my work unit for a few weeks and I'm nowhere near 115kg yet.
I probably will get larger equipment when I have more space but for now the smaller and cheaper the better.
