I'm having trouble finding a relatively cheap set of squat stands for a 5ft bar. Most I have found are either too big or too expensive so if anyone knows of a set for a reasonable price i'd appreciate it![]()
Those will work with a 5ft bar fine seeing as they're seperate - but only support up to 115kgwould this be enough for you?
Since they're independently positionable I can't see a reason why they wouldn't be suitable for a 5' bar. Might it be worth considering getting a longer bar if you can't find suitable racks?
