- 19 Jan 2008
- Sunny Wales.
You got the wrong tubing. Peeps said 7/16" tubing over 1/2" barbs. Compression fittings you have to buy the matched tubing and fittings.
It's not trial and error - it's reading instructions and advice.
7/16 is 7/16
1/2 is 1/2
7/16 (which is smaller than 1/2 [8/16]) and will fit very snugly on 1/2 barbs.
BUT compression fitting are different - read the sticky and please do some research before you get water all over your pc.
It's not differcult or elitist but you need to be careful and know what you are doing.
Edit: Oh and compression fitting are a pita if you get your tubing even slightly wrong.
It's the reason people don't recoment them to first time users.
7/16 is 7/16
1/2 is 1/2
The comps are fine to use but hes just going to have to buy some more tubing thats the right size. Can you give a link to the exact ones you bought?
the lose part slots over the end of the tube (tight section away from hose end)
To the OP, in case you don't grasp what is being said, if you look at the last of your pictures, the "lose part" is the fitting you have on the end of the that tube. That fitting should first be on the other way round, and second should be able to freely slide up and down the tube. Clearly the OD of the tube is much too big for that.
In the meantime I will purchase 1/2" tubing to with the 1/2" compression fittings I have...if anyone has any objections please say so now otherwise I thank you all with your help and suggestions![]()
Hold, make sure you get 1/2" OD tubing, which is usually 3/8" ID tubing, if you are sure your comp fittings are design for 1/2" OD tube. I won't mention 10/8mm tube. Oops I just have. Most people when they refer to tubing will say 1/2" or 3/8" without specifying they usually mean the ID.
To be absolutely sure take a ruler to that lose fitting in the last picture and measure the diameter of the hole. If it is greater then 12.7mm then it will at least slide up and down the tube you specify above. I have to take your word for it the compression fittings you have are designed for 1/2" OD tube as I have no experience of them myself, and the common ones I have seen have been designed for 10mm OD 8mm ID tube.
NO!
1/2 OD outside diameter
The link is to 1/2 ID inside diameter - the stuff you need is not available here.
as the walls are 1/8 thick giveing 5/8 OD
my slow edit from before.
Looks like you have tube that is 7/16 ID 5/8 OD
but compression fitting that need 3/8 ID and 1/2 OD - you need to buy some 3/8 tube with 1/16 walls not available here. 3/8 ID + 1/16 wall + 1/16 wall = 1/2 OD
Clearflex 60 and the XSPC stuff is surposed to work but you will get kinksas the walls are 1/8 thick giveing 5/8 OD
Masterkleer Tygon and Feser all make the stuff.
ID inside diameter - OD outside diameter
Sorry for sounding harsh.
Measured and its definitely smaller than 12.7mm so the tubing I bought with it was definitely the wrong size...I have found the right tubing on a competitor site (since OcUK seem to be going out of stock on jsut about everything watercooling) so I will buy them there...
The hole is smaller than 12.7mm? So it must be designed for 10/8 tube? You're getting me confused now. To be absolutely sure, looking at the last picture in your set above, the fitting which is on the tube, the diamater of the hole facing us in the picture, is less then 12.7mm (1/2")? What exact diameter is that hole?
