It's psychological. There's nothing inside a PC which can give you a stomach ache, certainly not fans.
In my experience, there's pretty much no limit to the conditions that your brain can make you feel. I think this will only get better when you really convince yourself that the PC isn't causing a problem. Until then, your mind will play tricks on you. You need to change your mindset because thinking excessively about problems like this just reinforces the association and makes them harder to shift.
