So I have a mouse in my house
I had a serious mouse infestation a couple of years back and went out and got those sticky things. Never again though. I know that they are pests and what have you, but it was very sad to wake up in the morning and find an almost-dead mouse lying stuck to one. Wish I'd have considered that part before I bought them :(
I wouldn't keep a mouse caught in a trap as a pet... these are not the same sort of mice you will buy from a pet shop (ie: not bred in captivity) and are likely to have all sorts of horrible diseases :(
What you need to do is nip down the shops and get your self a cross-bow, some hunting attire and a little stool to purch your self on.
Ring work and say you've gone hunting for a week, then start the waiting game....
Cross-bow beats all!
A proper cat which likes hunting, not a wimp :p.
One of mine does like hunting (as witnessed by me when he flings half dead mic einto the air and they land on the hood of the car), he just doesn't like hunting outside if the weather is sucky :D
The second one is scared of mice though :/ He runs away if they come near him (seriously - what kind of cat is that?)
lol, reading that title just reminded me of a ex that used to refer to her time of the month as 'there is a mouse in the house'.
Never trust anything that Bleeds for 7 days & don't die. :(
Save the Mouse, Save the Universe !!!
I was strangely satisfied knowing that the thing that had kept me awake for days on end had been electrocuted in a vicious manner.
My sleep is the most valuable thing on the planet.
Im being deprived of my sleep in uni. Parties till 4-5am, 2 nights out of every week. Seems exams has stopped it for a while.......
Who cares if the trap is humane or not? Mice are vermin ffs.
Some people need to grow a spine.
I'd find where they're coming from, seal it from all angles, and let the little critters starve.
I care, because I think killing them slowly and painfully is wrong and unnecessary. If you're going to kill something, do it quickly and minimise the suffering otherwise don't do it at all. I don't care if they are "vermin", that doesn't change the point.
Yeah, because it takes a tough man to slowly inflict pain on something 1/20 the size of you. :rolleyes:
You're more vermin than they are.
I think the best way to kill them is via a snap trap. They're quick and effective. Poisons are generally a bad idea because they might die in your walls and you'll get a horrible smell, then there's the possibility of non-target animals get poisoned too. And if you've ever seen your dog in horrible pain from these poisons, you wouldn't want to poison another animal again. And as far as glue traps go, they are horrible devices and should be illegal on the basis that they just torture the animals rather than kill them outright.
Rodents (especially rats, but to an extent mice) are neophobic. That means they're very wary indeed of new objects. With this in mind, you'll need:
Spring loaded traps (vary number according to the size of your place, 2 a room is OK)
Poison bait stations (Rentakill or The Big Cheese etc)
Chunky peanut butter and/or Nuttella (cheese is a myth, but rodents go mad for these!)
Bait the traps with a generous dollop of peanut butter/Nuttella and set along skirting, close to the wall and preferably behind objects (wardrobe, fridge, cooker, washer etc) where you've seen rodent activity. Put the baited end closest to the wall. Set bait stations in similar locations for maximum effect, but don't place a trap AND a bait station in the exact same space.
Remove ALL food sources from the floors (unsealed bins, bags of dog/cat/animal food, etc). Then, survey the OUTSIDE of your property - they're getting in somewhere. Any hole big enough to fit a biro in is big enough for mice to enter. Buy a roll of weldmesh/fly screen and a can of expanding foam. Stuff a piece of mesh just bigger than the hole into each one to make a tight fit, then fill the hole with enough foam to slightly over-fill it. Double check around pipe entrances, gas meters, phone/sky/aerial cables etc. Make sure you close ALL holes.
The rodents are now trapped in your house with no escape. They will be forced to seek food and water inside your home rather than being free to enter and leave at will. The only food and water supply they'll have is the traps and bait stations.
Wait. :D DO NOT disturb any traps or touch bait stations once they're laid. They'll need to be left to become part of the 'fixtures and fittings' before rodents will consider going near them. If they are disturbed regularly they'll have a 'new' scent about them and stink of human (which you don't want!). Only touch a trap if it's caught a mouse, in which case bin it and set another, or (if reusable) release the rodent into a bag and bin it before relaying the trap.
Good luck. :)
Great advice, but I'd be cautious about using poisons. But ideally, you should seal all holes internally just to make sure. Give them no chance to even enter your house in the future.
lol seen this thread and though of my nephews hamster rastas who is on the loose has escaped from his cage , loving it winding my sister up telling her freddie starr ate it
hopefully he doesnt end up pan bread hes just new and not even hand trained yet the hamster has the fear lol loves the chocolate buttons but wont come oot his pipe :(
boooo
They carry disease and cause damage to people's homes. I don't care what size they are, they're vermin. If the most effective method of removing them is painful death, so be it.
There's nothing "tough" about that, it's called protecting your family and home from an unwanted invader.
I guess you're one of those spineless gimps I mentioned above. "Oh don't hurt the poor little mousey mouse!"
Either that or you're trolling, in which case I suggest you go read the rules.
Tute, on the one hand Gavin has only posted that if you're going to dispose of rodents why not do it in as quick and painless a way as possible, if possible. That's not really trolling any more than saying you can't care less if they die in agony, since they 'invaded' your home, surely? ;)
On the other hand, Gavin only signed up to reply to my ratting (hunting with dogs) thread in February... and has only posted in that thread until today. Today he posts in the mouse killing thread. Which organisation are you a member of then Gavin? RSPCA? PETA? Just wondering... :p
Well I fail to see how people can care more about the mouse's feelings than their own family's.
And I was simply pointing out that it could be trolling, given the "either that, or..." - I posted my opinion and I believe he posted his, I was merely questioning if that was indeed the case.
I see now. Not trolling, the other one. ;)
