i dont think you can. i believe the best way is to forward everything you do want to a new email address, then set the blackberry up with that.
Yes you can set up email finters in the BIS control panel?
Never used them though so not sure exactly how they work.[/QUOT
How do i get that i'm with o2?
Anyone know a good screen protector for it?
From the device you'll need to create a user name by clicking on the email settings icon in the set up folder. Then, once you have a user name & password go to www.o2email.co.uk and log in using your new credentials.
Can I get satnav software for it? Want to make better use of GPS!
got my filters setup last night, really useful..
ok next question! why when i first had the phone did it flash blue when i got a msg and now it's red lol
coincidence methinks - Blue signifies a Bluetooth connection, red signifies new message, green signifies signal coverage (which I switch off as it's just annoying - of course I have a signal, I live in a city! I'd rather have a no signal indicator).
You can get apps to change those indicators though, but never used one.
Best app for changing led colours is Berrybuzz...you can set various colours for notifications and also has the vibrate and ring function within it...i use it on both my Bolds and its superb...only $5 or something like that...u can get it from crackberry app store or the RIM app store.
