- 13 May 2009
I'll give you a quick run-down of my situation:
I bought as computer from Mesh about 2 years ago and have had nothing ut trouble with it. I've even been extorted out of several hundred pounds (the lesson: avoid Mesh like the plague). I'm currently in the process of getting all my money back (hopefully ending soon).
Mesh have actually blatantly lied to me about all sorts of hardware failure I've had over the last two years, and I've lately narrowed it down to heat.
I had an 8800gtx and it was hitting 80-90c under strain and sat at about 60c idle. Not good at all. After having it with crashes that collerated with the intensity of the task and the time the computer was used (plus I suspected failing hardware) I got myself a GTx260 from OcUK. Fabulous so far. It runs about 30c cooler than the 8800. The only problem is I still have signs of overheating (mainly stuttering framerates and graphical glitches), but not to the extent the previous card had.
I noticed on both the 8800 and the 260 that it usually takes several minutes for it to cool down to its idel temperature, and sometimes it sticks 10 degrees above.
The case Mesh have provided has two front case fans and a 500w PSU. It's incredibly cramped in there (it was a miriacle they got the 8800 in there) and the CPU heatsink is very close to the PSU, which I understand can lead to overheating.
I've got my eyes on an Antec 900 case. Does it sound like I should get a case that isn't like a pressure cooker?
[Edit] Also notable- there doesn't appear to be any difference in temperature between SmartFan and all fans set to 100% manually.
After about an hour of use this is what SpeedFan reads:
GPU: 46c
System: -65c
CPU: 32
AUX: 35c
Core 0: 29c
Core 1: 25c
GPU: 46c
System: -65c
CPU: 32
AUX: 35c
Core 0: 29c
Core 1: 25c
thats hot, and my system is at like 50c and its in a big armor
