- 18 Mar 2009
- Indiana, United States.
Hey mates,
I have read up on sli and crossfire and there I had some questions reguarding what I read.
Some claim that it doesn't work or doesn't work very well with some games and therefore you would be better off to have just one good card
I have also heard that 2 cards with 512mem is not the same as one card with 1gb mem. Also that if I went SLI with my 285 I was told I would not be able to up the draw distance more or anything because It wouldn't use the vid ram on the second card like I would think it would.
So is SLI just basically for more fps? I know it helps with larger resolutions so is it useless unless you have dual monitors or high resolutions?
Thanks for any help in advance.
so it kinda sucks to see fps drop from 80 to 40 when you pull out your weapon. So I compromise there and use SLI AA so atleast I get a nice visual boost even with the lower framerate.
