- 18 Mar 2009
- Indiana, United States.
Hey mates,
I have read up on sli and crossfire and there I had some questions reguarding what I read.
Some claim that it doesn't work or doesn't work very well with some games and therefore you would be better off to have just one good card
I have also heard that 2 cards with 512mem is not the same as one card with 1gb mem. Also that if I went SLI with my 285 I was told I would not be able to up the draw distance more or anything because It wouldn't use the vid ram on the second card like I would think it would.
So is SLI just basically for more fps? I know it helps with larger resolutions so is it useless unless you have dual monitors or high resolutions?
Thanks for any help in advance.
