Hi , i found a pc on the "OC" store which looks really cool, just i am thinking on changing 1 video card at very same moment i buy it and the second in a year or so. the video cards i would like to use are geforce gtx 295.
pc spec:
Intel Core i7 920 D0 Stepping (SLBEJ) 2.66Ghz @ 3.60GHz Overclocked!
- Gigabyte EX58-UD3R Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard
- OCZ Gold 6GB (3x2GB) DDR3 PC3-10666C9 Low-Voltage Triple Channel
- Nvidia & ATI Performance Graphics Card Options
- Akasa AK-967 Nero Direct Contact Heatpipe CPU Cooler
- Seagate Barracuda 7200.11 1.5TB SATA-II 32MB Cache - OEM (ST31500341AS)
- LG GGC-H20L Blu-Ray Reader & HD-DVD ROM Serial ATA Drive Option
- Corsair TX 850W ATX SLI Compliant Power Supply
- Arctic Silver 5 Thermal Compound professionally hand installed by our technicians
- 1yr Onsite Collect & Return Warranty
could this pc handle the video card i mentioned without causing any trouble? thx in adavance.
the porpose of this pc is going to be gaming also i am wondering if the another 6gb of ram could also do anything in mine favour? or it wouldnt change the performance that much? the tips are always appreciated
pc spec:
