Then get the faulty suspension components replaced.
Sounds like it just torque steers in the way you'd expect from a mediocore chassis with a bit too much power through it.
The right pedal has other positions besides full down and full up...
[TW]Fox;14150358 said:Sounds like it just torque steers in the way you'd expect from a mediocore chassis with a bit too much power through it.
I put Toyo's on my car for £65 a corner![]()
DSC negates the need for driver. Fact.
Doesn't pull to either side like torque steer is suppose to under hard accelleration, only loses control when cornering at speed. Just off the line it wheelspins a fair amount.
New Ti comes with P6000s all round, should be better![]()
maybe i'm thinking of recaps![]()
I payed £200 for a tyre yesturday!![]()
Only tyres you'll get for £20 each are 12" or smaller, mate. That's nankings for the mini![]()
