have you the wallpaper....
If you want to fit the AM on either change the font size to something smaller (right click the rainmeter icon - choose the hud and then edit settings) or change the area from 400 to something bigger.
M.
thanks for that mate
Have the name of the gadget in the corner for date/time/weather mate? Seen it on a few here and can't find it via searches![]()
The weather and big time is Rainmeter and the 10-foot-hud addon.
Not sure about the translucent items though.
M.
The application is called Rainmeter and the time/date & weather are part of the 10-Foot HUD skin
Here you go: http://lifehacker.com/5084412/configure-your-own-rainmeter-10+foot-hud
M.
Just having my first play around with Objectdock and Rainmeter:
http://img529.imageshack.us/img529/2456/73280563.png[IMG][/QUOTE]
Looking good, got a link to the wp?
snip
which weather add on is that? I'm looking for a better one than the 10ft hud weather. a uk one would be ideal cos I cant get accurate weather reading. think its set to edinburgh but I'm further north.
