Just wondering - you using headphones or speakers?
as the title said i just got a sound blaster x-fi extreme gamer and bl**dy hell it makes a difference over onboard to my music and counter strike source.
sorry i just had to tell someone![]()
What onboard soundcard was it?
I have the same card. Makes you wonder why you put up with onboard doesn't it? Some people will tell you that onboard is just as good as a dedicated card but it's simply not true.
Is it worth the extra money? I need to be converted....
Guys, it can't make that much difference can it?!
I've never heard a system with a decent sound card to be fair so I wouldnt know.
But onboard sound comes with 'Home theater quality 8-channel High Definition Audio' sound nowadays so I just assume its pretty decent sound comming from the onboard.
think of it as a tesco value high definition screen vs a samsung one..
they're both high def, but you know which one you want![]()
meh, onboard is fine, if you're using a DAC that is...
Analogue out's tend to be awful however....
