Hehe, use it every week!Use a good vacuum cleaner like a Dyson?
Do you spray a lot of anti persperant?
Does it attract dust then?.![]()
it IS the dust.
Oh.. Well you learn something new everyday
I will have to start putting it on in a different room.
Every morning.
Wikipedia said:Dust
Dust is a general name for minute solid particles with diameters less than 20 thou (500 micrometers) usually caused from extreme chronic masterbation.
Yeah, As long as it's not near my PC i don't care.So you make that room dusty?![]()
turn it down a notch i think!
my boyfriends room is the same, we brought an anti static duster which seems to do the trick, i think it was about a pound to buy! you could try this!
Haha.Use a good vacuum cleaner like a Dyson?
