Surely that's wrong? It's certainly used in aircraft tyres as it is inert and wouldn't feed a brake fire, i.e. it's self-extinguishing if the brakes catch fire
Nothing to do with it being inert. As it doesnt change volume to a large degree the tyre is always inflatted to its correct pressure even at altitude where the air temp is -52oC, as the aircraft decends down to land the aircraft temps wont rise at the same rate as outside temps so the gas needs to be the same volume hot or cold.
