Cleaning the car in the right order.
18 Oct 2002
South Wales
Just got my new car :D so have ordered a few products to clean it.
I have ordered:
Quik Clay Detailing System
Hyper Wash
Supreme Shine Microfibre (single)
Endurance High Gloss Tyre Protection Gel
Luxurious Lambs Wool Wash Mitt
Scratch X (for scratches and swirl marks).
Terry towel
Would this be the correct order to clean the car in?
1. Wet the car down with water
2. Use the lambs wool mit + the hyper wash to wash the car.
3. Dry car down with Terry Towel
4. Use the quick clay detailing system
5. Scratch X to remove swirl marks ect.
6. Auto glym Super Resin Polish
7. Should I get something like a wax or sealant to protect my hard work?
Also with the clay system, I know its sounds stupid but how do you actually use it, do you just use the whole block and go all around the car with it, or can you break it off and use different bits for different sections (I have never used it before)
I have ordered:
Hyper Wash
Terry towel
id personally clay before drying as its recommended to wash the car again after claying.
I choose
Pull in
Fiddle with radio or phone
Open window
Hand over money
Blast off up the road with Sport button pressed
Yes get some wax or sealant the SRP doesnt last long on its own, Autoglym Extra gloss protection is a decent sealant that works well over SRP.
My friend said to split it up. Use one bit then throw it away then have the rest for another time.
Personally, today I washed my car for the first time since the garage did it at MOT time in March! I just did a spray down, wash, rinse spray down and dry. Now last year or the year before when I did it cleaned it more frequently it would be a more smooth shiney finish. I think it may be time to add some touch up pen, polish and clay to the process the next time. I've got all the gubbins but I do get bored after about an hour of doing it so it is good to know the order of things for when I get a nice day to spend doing the whole car!
Thanks for the cleaning thread link.
I either get bored or simply don't have more than an hour or two so I just polish and wax a panel or two at a time.
I also prefer doing it this way so I can tailor what is needed. e.g. on my bonnet where 2 cats looked like they had a fight on it :mad: I went for three stages of polish followed by wax where as the following time when I just did the roof I just gave it a quick go over with SRP followed by wax.
I choose
Pull in
Open window
Hand over money
Same, minus the sport button :)
I grew out of washing my car every week. A lot of effort for a couple of days satisfaction. I like taking pride in my things but i'd rather pay someone £6 to clean my car personally. They do a decent enough job.
