- 18 Oct 2002
- South Wales
Just got my new car
so have ordered a few products to clean it.
I have ordered:
Quik Clay Detailing System
Hyper Wash
Supreme Shine Microfibre (single)
Endurance High Gloss Tyre Protection Gel
Luxurious Lambs Wool Wash Mitt
Scratch X (for scratches and swirl marks).
Terry towel
Would this be the correct order to clean the car in?
1. Wet the car down with water
2. Use the lambs wool mit + the hyper wash to wash the car.
3. Dry car down with Terry Towel
4. Use the quick clay detailing system
5. Scratch X to remove swirl marks ect.
6. Auto glym Super Resin Polish
7. Should I get something like a wax or sealant to protect my hard work?
Also with the clay system, I know its sounds stupid but how do you actually use it, do you just use the whole block and go all around the car with it, or can you break it off and use different bits for different sections (I have never used it before)
I have ordered:
Hyper Wash
Terry towel
