Don
- 20 Oct 2002
- In a house
Took a pic of my main planted tank, and my blue clawed crayfish last night, figured i would post them.
I don't feed them. And no I don't have CO2 addition.![]()
You should look at getting something like Tropica Plant Nutrition+ to feed the plants, Some Liquid carbon from the likes of Seachem, or maybe a CO2 unit. What size tank do you have, and what is the wattage of your lights?
I have 2 x 15w lights. The tank is 115 litres; length 58 cm,width 38 cm and height 54 cm.
So you've got about 1wpg (watt per U.S gallon) that would be low/medium amount of light. What type of plants do you have? when you bought them you should've got a little card with them it'll tell you what the requirements the plant needs (with regards to PH level, temp & lighting) you'll struggle to keep plants that need a lot of lighting in a tank with low lighting levels.
Heres the thread I did about my tank (page 2 for up to date pics.). At the moment my lighting isn't much better than yours so I'm looking at upgrading the lighting from 36W T8 lighting to something like 96W T5 lighting and getting a pressurised CO2 system.
I have purchased some nutrients for the plants and will observe if this has any affect on their will being. The tank itself is looking really good now although I may consider upping the wattage of the lights. The good news is the plants are starting to root now, its just that their leaves are transparent / brown.
mmmmmmmmmmmm yummy Crayfish
