In what way? All 80's cars fail at safety so I wouldn't worry.
I'd say MX-5, fantastic car to drive, if I didn't have the 200SX i'd have got one of them.
good suggestion bar the fact he wanted good looks
Teg Si would probably be better, one with LSD.
Nope 2.2 in the Prelude (H22 / H22A)
and 1.8 in the DC2 type R (B18C5)
The Vtec in the DC2 kicks a lot harder than the Prelude, but the preludes better to drive off vtec thanks to it's bigger capacity.
Although interestingly, the Preludes 280mm brakes are considered an upgrade to the DC2's standard 260ish. Maybe not so interesting.
still ... fwd![]()
Honda Prelude 2.2 VTEC.
 but i am biased.
	As long as you have the hands and arms of a 5yr old you should be ok.
Are mr2s reliable? I always imagined they would be a bit of a bitch to work on?
Only because your MR2 has a massive crumple zone where an engine should be![]()
  6 grand though isnt exactly cheap
They like to oversteer in corners and then roll a lot. This rolling coupled with a tin foil roof equals bad times. But granted they are almost 20 years old so its to be accepted.
