Rip To .FLAC
dBpoweramp is total awesomeness. It managed to rescue my Michael Jackson CD which was scratched near the end and jittered like hell.
You can also use Foobar.
EAC wins by a country mile and a half.
Once setup, pop in the disk, get the FreeDB to tag it and then hit rip, forget about and its done.
I keep trying different versions of EAC and for some reason it won't detect cds inserted into my optical drives on my PC. On another machine they're detected fine with a free little utility called "Freecdmp3ripper" which can convert to *.flac and *.wave files.
From memory that sounds like an aspi driver issue.
Can dBPowerAmp make as good a rip as EAC (down to the picky probably-placebo settings level)? It is a much better designed app.
The full paid for version can I think, but unless your discs are really scratched to pieces then I doubt you would notice the difference even in the free versions.
dBPoweramp is a lot less hassle and it has that auto cd database checking thing.
Can you do anything if you don't have the CUE file?
Yes, you can burn a CD directly from FLAC files using most software eg burrrn, nero etc but you won't have the correct gaps between the tracks. The only way of getting an identical copy of the cd with correct gaps is with a correctly created cue file.
