Can someone explain this code to me? Does it just keep trying the same code or do you have to have one in your clipboard or something? Ive copied the code from this page and have it running currently...
Do those really working the system actually need 10 balls? It just... Umm... Seems a little selfish? First off it means those that actually do need one (Or may legitimately have won one after buying a product) stand less chance of getting them and means the companies are less likely to offer these sorts of promotions in future.
I can understand the achievement of "cracking" the system... But to then just keep obtaining ball after ball for no reason seems odd.
Don't get me wrong... I'm not starting on the whole "Holier than thou" because I did, after reading this thread, try for a ball myself and won one (Using the GMail method of obtaining many codes; At that time I didn't realise the same code could be used over); Partly to "see if it worked" but with the intention to give it to my girlfriends brothers (Anybody who knows me knows I'm unlikely to get any use out of it!!).
C'mon guys... You've proved you've got the system understood... How about now leaving the balls to somebody who actually wants/needs them?![]()
my parents will undoubtedly find it bery amusing when 10 balls turn up in the post.
You just paste a code in place of the red text "your_code".
It tires the same code over and over.
For the 1st x times, it wil loose.
Than after x times it wins every time.
Just look at it every so often, sooner or later you will see the winners form on the screen, stop the code, fill it in, done.
Keep the football flash animation in sight on the screen the whole time, I don't think it works if it's behind other windows.
I'm getting this error every now and again
RuntimeError: element SPAN specified by CLASS:abspos was not found, line 8
SET !REPLAYSPEED FAST
SET !REPLAYSPEED MEDIUM
SET !REPLAYSPEED SLOW
Change this line
to:Code:SET !REPLAYSPEED FAST
or:Code:SET !REPLAYSPEED MEDIUM
Code:SET !REPLAYSPEED SLOW
I realy want a rugby ball, any guaranteed way of getting it? I'm guessing its pot luck and your 'Favorite Personality' doesn't decide.
