FREE - football, rugby, and cricket balls
Do those really working the system actually need 10 balls? It just... Umm... Seems a little selfish? First off it means those that actually do need one (Or may legitimately have won one after buying a product) stand less chance of getting them and means the companies are less likely to offer these sorts of promotions in future.
I can understand the achievement of "cracking" the system... But to then just keep obtaining ball after ball for no reason seems odd.
Don't get me wrong... I'm not starting on the whole "Holier than thou" because I did, after reading this thread, try for a ball myself and won one (Using the GMail method of obtaining many codes; At that time I didn't realise the same code could be used over); Partly to "see if it worked" but with the intention to give it to my girlfriends brothers (Anybody who knows me knows I'm unlikely to get any use out of it!!).
C'mon guys... You've proved you've got the system understood... How about now leaving the balls to somebody who actually wants/needs them? :)
Can someone explain this code to me? Does it just keep trying the same code or do you have to have one in your clipboard or something? Ive copied the code from this page and have it running currently...
You just paste a code in place of the red text "your_code".
It tires the same code over and over.
For the 1st x times, it wil loose.
Than after x times it wins every time.
Just look at it every so often, sooner or later you will see the winners form on the screen, stop the code, fill it in, done.
Keep the football flash animation in sight on the screen the whole time, I don't think it works if it's behind other windows.
My nephew is getting a lot of my haul. Which still stands at 10, as I've stopped for today. The 100,000 sure will pass quickly.
I also had them sent to the Lakes (I'm in Shampton ATM), so my parents will undoubtedly find it bery amusing when 10 balls turn up in the post.
Tomorrow I might take a few orders, I know there are some peeps desperate for a Rugger ball.
But that's the point... You seem to be getting as many balls as you can because you can... I don't see the logic in continuing. You've worked the system out, have explained it to others and have got yourself a few "souvenir" balls, if you like, but beyond that... What's the use?
EDIT: Just seen your edit, fair play.
Thanks mate.
Won one football - Id love a cricketball though. Which player were you guys choosing to get a cricketball?
After my current haul arrives I may try some more exotic tests, like using a code which has won, and making codes up. I think this is why I do it, my Job is testing in IT. It's in my nature to break computer systems.
I realy want a rugby ball, any guaranteed way of getting it? I'm guessing its pot luck and your 'Favorite Personality' doesn't decide.
Not so sure.
Was winning tons of footballs with Beckham.
Changed to Henman and won my first cricket ball.
Try choosing George Best. I got two rugby balls with him.
