- 20 Apr 2008
- West Midlands
never been a problem for me either until either a) an installed programme has messed things up or b) it doesn't like installing with crossfire connected?
I have found that I have to disable my AV (Kaspersky) when I install and uninstall the ATI drivers, or the process will fail.
so glad i've never had a problem installing any drivers nvidia or ati
I've always installed over old drivers
this has worked![]()
bledd will be happy i'm not ditching ATI![]()
heh
actually I mainly run nvidia cards
just didn't want you to take the shotgun blast approach and waste money
glad its sorted![]()
As has been said, it's a broken OS install - nothing to do with ATI or Nvidia.
Process for updating ATI drivers.
Run latest driver executable.
[/end]
Done this since I've had the 4870 and it's always worked fine. Find Drivercleaner, safe mode and 90 restarts to be way overkill.
To echo everyone else, sounds like your install is shafted. Either that or the card has issues... Going Nvidia isn't the solution.
mine turned out to be Kaspersky. Issue now is it creates artifects in Vantage.
Unsure on games but shall try later.
If it appears in games then i shall go back to 9.5
