- 7 Nov 2005
Hi,
My flat was broken into last week and the locksmith put this bar across the window and I would like to put another couple across as a deterent. The windows are quite long and thin and really needs to be white so it looks less like a prison
My google skills are failing and can't find anything on the B&Q site that would resemble this. It's metal as you can see just about 0.5cm thick.
If anyone can find a shop that I could buy them I woul be very grateful. Can't think what to search for that doesn't bring up lots of results.
Cheers.
Cheers.
