Help me find a shop that sells these metal bars please
7 Nov 2005
Hi,
My flat was broken into last week and the locksmith put this bar across the window and I would like to put another couple across as a deterent. The windows are quite long and thin and really needs to be white so it looks less like a prison :o
My google skills are failing and can't find anything on the B&Q site that would resemble this. It's metal as you can see just about 0.5cm thick.
If anyone can find a shop that I could buy them I woul be very grateful. Can't think what to search for that doesn't bring up lots of results.
Cheers.
I don't have the locksmiths number. It was done through the mangement agent but I will ask if I can't find anything suitable.
You wouldn't be able to see the screwheads form outside the window so but would hopefully be enough of a deterent. I live on the ground floor!
Try to find a window security grille, much classier and easier to install than 12-odd metal bars.
http://www.authorized-access.co.uk/services/doors-grilles-shutters/fixed-bar-systems
Thanks and I would rather this but the landlord isn't keen to install fixed grills. I can remove these when I move when my lease is up.
That window opens outwards...........
I think a fail is in order.....
It's a deterent to hopefully stop anyone trying to bother getting the window open which is now secured by multi purpose bolts top and bottom and 1.5 inch screws in both handles.
B&Q or somewhere like that would probably sell them.
I've tried looking but I can't find anything on their website?
If the landlord doesn't want to bother then just get your stuff insured, take pictures of everything and keep them offsite, and then who cares if someone breaks in? Let the landlord deal with it.
